Browse Forums General Discussion 1 Mar 08, 2024 12:49 am Hi! I am in the market for a two storey warehouse. I've found a single story brick warehouse that could be ideal if I could just raise the walls. It's nothing more than 4 brick walls and a steel framed roof. Is this possible? I imagine that it would require a bit of engineering and additional support, but I wonder if it would take more than that, or if it would be cheaper to pull this down and start again. Any info would be greatly appreaciated. Re: Extending Brick Warehouse Up 2Mar 09, 2024 11:31 am There is insufficient information to give a meaningful answer. You should talk to council planning. Apart from building construction issues, if you are adding floor area you may need to provide more parking. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog If your patio is going to be 35 sqm then that's going to need Council Approval. The fact that they previously approved your 25sqm patio will be irelevant 1 5750 Ask for some kickplate to be added and also for tradies to be requested to use lanyards on tools on that side of the building. Be respectful and have the discussion… 1 1821 Hey all Currently renovating our laundry, bought a new washing machine but have found that the drainage hose is alot shorter than the old machine (which I used to get the… 0 17818 |
