Browse Forums General Discussion 1 Mar 02, 2024 5:42 pm Flashings over doorways and windows our carpenter has installed flashings that is buckled and short of the window frames and door frames is this right Is there a measurement for this Cheers beb Window flashing Buckled not over window Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 11201 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6472 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10406 |
