Browse Forums General Discussion 1 Mar 02, 2024 5:35 pm Re: Door jambs 3Mar 02, 2024 11:46 pm All good. It's only paint grade so you can easily fill the heads. Back in the day they'd just use 3" nails to fix the frames. The bugle head screws will be strong and prevent movement. The only other option was to have fitted the frames before wall linings went on then they could have fixed from the inside back into the frames. But it won't make any difference either way Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Door jambs 4Mar 04, 2024 4:09 pm Pulse looks like it is done properly, are you in a cyclone area? Some carpenters don’t get this right, your’s is great, harder to patch but super strong. Hi Ok. Thankyou for that No we are in a Bushfire zone area out west in Perth region Ta Beb Re: Door jambs 5Mar 04, 2024 4:14 pm chippy All good. It's only paint grade so you can easily fill the heads. Back in the day they'd just use 3" nails to fix the frames. The bugle head screws will be strong and prevent movement. The only other option was to have fitted the frames before wall linings went on then they could have fixed from the inside back into the frames. But it won't make any difference either way Hi Thankyou Yes he shld of done it from the inside before the frames and wall lining went in Won't make any difference ok 👌 Will take your ad advice Thankyou very much really appreciate the comment Ta Beb Plasterboard Gyprock is very popular as a reveal liner these days. You need to provide a way of supporting it, we use a modified timber reveal or bracket. You will be… 1 4964 920 was enough to get the furniture in. We live in a pretty safe area and it’s great to see people walking to the front door. We’re not too fussed about people… 4 3117 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16770 |
