Browse Forums General Discussion Re: Garage Door Malfunction 2Feb 22, 2024 8:19 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Garage Door Malfunction 3Feb 22, 2024 8:35 am building-expert It looks like an easy fix with a longer screw right into the timber behind the packer. Yes its builders defect Yes the builder is liable to fix it under warranty Yes you can go to VCAT after you have been through DBDRV and it will cost you plenty. or Just get someone to fix it for you Thankyou! As you can see it will need new structural replacement to hold the door, replastering, painting, new anchor plate. The Torsion bars are bent, The roller door company who initially had a look to lower the door back for security doesn't know if the door is damaged further. So will be a few dollars I would imagine. Appreciated Dover white or surfmist garage door. I am having trouble choosing a garage door. The outside of house will be tranquel retreat. I want it to all blend nicely however I… 0 7116 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6731 My garage door has started playing up recently. Sometimes (and getting more frequent) when I press the button to open it, it wont. The motor is an ATA GD0-6V3. Red and… 0 2868 |
