Browse Forums General Discussion 1 Feb 19, 2024 9:13 am Not sure which section this belongs under. But during handover, Allcastle told me that Flick was the only one that could do termite control, I have since seen other company cars on the road indicating they also do that. So do i need to stick with Flick or is any of the others ok? Are the other companies same quality? both termite and pest control. and if anyone can share approximate cost for both and how long a treatment last Re: Termite and pest control 2Feb 19, 2024 4:48 pm There are many pest control companies that can maintain your termite management system, so shop around. Termite management system requires annual inspections or the warranty is void. Get your quotes, read your fine print. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Termite and pest control 3Feb 19, 2024 5:07 pm building-expert There are many pest control companies that can maintain your termite management system, so shop around. Termite management system requires annual inspections or the warranty is void. Get your quotes, read your fine print. So as long as its done by professional licensed companies, warranty is still valid? Flick isnt the sole campany that can offer warranty? Re: Termite and pest control 4Feb 19, 2024 6:11 pm Bao Nguyen building-expert There are many pest control companies that can maintain your termite management system, so shop around. Termite management system requires annual inspections or the warranty is void. Get your quotes, read your fine print. So as long as it’s is done by professional licensed companies, warranty is still valid? Flick isnt the sole campany that can offer warranty? Warranty is provided by the company that maintains termite management system. As far as I know there is no monopoly on termite management. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Termite and pest control 5Feb 19, 2024 6:25 pm building-expert Bao Nguyen building-expert There are many pest control companies that can maintain your termite management system, so shop around. Termite management system requires annual inspections or the warranty is void. Get your quotes, read your fine print. So as long as it’s is done by professional licensed companies, warranty is still valid? Flick isnt the sole campany that can offer warranty? Warranty is provided by the company that maintains termite management system. As far as I know there is no monopoly on termite management. Fantastic. Good to know. Thank you very much Hi group, have some damage to the door frame and skirting board. It's a side door to the laundry area. Only has a security door. I had a termite inspection (note drill… 0 5511 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7748 Hi All, First time poster. I was hoping to get some advice on villaboard installation within a bathroom. I have installed villaboard before, in a laundry. I think I did… 0 7760 |
