Browse Forums General Discussion 1 Jan 18, 2024 12:48 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi It came to my attention after the handover that - The facade cladding on the face and the side are not straight. -The face tapers down by 50mm from left to right and is visible from the street The edges from the internal porch area are all 40mm. and I cant put my finger on how the face facade is longer on one end. If the face was not constructed straight then surely from the porch you could see a drop similar to the face. Side facade The side was initially installed parallel but at a later stage the builder changed it due to defects The brick column is parallel to the wall, however on the top, the render sheeting is at an angle towards the house. 1 9564 All 3 items listed are defects and are of concern. Please seek qualified independent inspector and/or legal advice for your state. 1 8360 The significant date is when receive final payment invoice Check that section of contract Bit of fluff by builders prior to that 1 16064 |
