Browse Forums General Discussion Re: Concreting over concrete? 2Jan 16, 2024 3:19 am Yes you can. We typically aim for 80mm of cover over footings and existing concrete. You can probably get away with a little less however if you want to make sure you don't end up with cracking then try and keep it as thick as possible. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Concreting over concrete? 3Jan 16, 2024 5:50 am Thanks so much for your reply. How would you recommend chipping away at this, to not damage the sturdiness’s of it? Cheers chippy Yes you can. We typically aim for 80mm of cover over footings and existing concrete. You can probably get away with a little less however if you want to make sure you don't end up with cracking then try and keep it as thick as possible. Re: Concreting over concrete? 4Jan 16, 2024 6:15 am You could use a handheld grinder with a concrete cutting tool to be precise of provide some initial deliberately located cuts to ensure it breaks at that point. The rougher way would just be to use a SDS hammer drill on hammer only mode or a jack hammer to make lighter work of it and just chip at it. Re: Concreting over concrete? 5Jan 16, 2024 6:25 am jas25t You could use a handheld grinder with a concrete cutting tool to be precise of provide some initial deliberately located cuts to ensure it breaks at that point. The rougher way would just be to use a SDS hammer drill on hammer only mode or a jack hammer to make lighter work of it and just chip at it. Thanks mate. Much appreciated. Re: Concreting over concrete? 6Jan 17, 2024 6:46 am SamMac Thanks so much for your reply. How would you recommend chipping away at this, to not damage the sturdiness’s of it? Cheers chippy Yes you can. We typically aim for 80mm of cover over footings and existing concrete. You can probably get away with a little less however if you want to make sure you don't end up with cracking then try and keep it as thick as possible. We would cut the conc with a quick cut. Just cut to the depth you need and put a number of slits across the concrete about 20mm apart then knock them off. It would take about 5 minutes per footing to cut and knock it off. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Concreting over concrete? 7Jan 17, 2024 7:05 am chippy SamMac Thanks so much for your reply. How would you recommend chipping away at this, to not damage the sturdiness’s of it? Cheers chippy Yes you can. We typically aim for 80mm of cover over footings and existing concrete. You can probably get away with a little less however if you want to make sure you don't end up with cracking then try and keep it as thick as possible. We would cut the conc with a quick cut. Just cut to the depth you need and put a number of slits across the concrete about 20mm apart then knock them off. It would take about 5 minutes per footing to cut and knock it off. Yep. Giving it a crack this morning. How close to the steel post you think? Re: Concreting over concrete? 8Jan 17, 2024 7:18 am Just get as close as you can without hitting the posts. Once you are close to the edge of the path the chance of cracking is minimised. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8741 We've had decent weather for last 7 weeks and now the drvieway has been cut out we had an evening of 50mm of rain including all the water from half the street, ground is… 0 4581 Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6625 |
