Browse Forums General Discussion 1 Jan 07, 2024 10:26 pm So... I'm painting some barndoors in black gloss. I gave up on the aquanamel paint and moved to a oil based gloss enamel. However, regardless of the application method (roller, roller and brush, paint gun) the paint has little bubbles form. Most pop as it dries, but some don't and being gloss and black, grey are ultra visible. I've tried thick coats, barely there coats abd cant get it to dry smooth. The best so far has been rolling, then laying off with a brush which pops these bubbles....but I walk away and more bubbles form. What is going on here? Also I've looked at additives, but floetrol is for waterbased, penetrols australian version doesn't read the same as the American version, so unsure it's the same. Anyone have any tips? Re: Black gloss enamel 3Jan 09, 2024 2:22 pm Painting is a system, have you followed manufacturers instructions re, primer, undercoat and top coat? Also application of paint. Painting in hot weather, especially black, could be causing skin to form before solvents are expelled, therefore gasses trapped causing bubbles. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Black gloss enamel 4Jan 09, 2024 2:38 pm building-expert Painting is a system, have you followed manufacturers instructions re, primer, undercoat and top coat? Also application of paint. Painting in hot weather, especially black, could be causing skin to form before solvents are expelled, therefore gasses trapped causing bubbles. yep followed manufacturer instructions to the letter. Sadly the instructions didnt adress nuanced scenarios. In anycase, Ive solved the issue. Penetrol worked a charm, creating a longer open time for teh paint, allowing the bubbles to escape and application marks to self level. Meaning i could use a brush for the whole job with zero brush marks. Re: Black gloss enamel 5Jan 15, 2024 9:54 pm ponzutwo So... I'm painting some barndoors in black gloss. I gave up on the aquanamel paint and moved to a oil based gloss enamel. However, regardless of the application method (roller, roller and brush, paint gun) the paint has little bubbles form. Most pop as it dries, but some don't and being gloss and black, grey are ultra visible. I've tried thick coats, barely there coats abd cant get it to dry smooth. The best so far has been rolling, then laying off with a brush which pops these bubbles....but I walk away and more bubbles form. What is going on here? Also I've looked at additives, but floetrol is for waterbased, penetrols australian version doesn't read the same as the American version, so unsure it's the same. Anyone have any tips? This link might answer your question. I had the same issue and it turned out to be the roller. https://www.sherwin-williams.com/painti ... %20coating. The yellowing mainly occurs to white or very light colours. 1 3067 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 7410 The warning is on the sticker on the door too. Second the aluminium powdercoat 6 19101 |
