Browse Forums General Discussion Re: Clarendon Eaves and Guttering Issue 2Dec 18, 2023 7:27 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Clarendon Eaves and Guttering Issue 5Dec 22, 2023 11:57 am The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this! Do the gutters pool water after it stops raining? Although it's hard to see in the photo, the gutter does appear to have overflow slots. Is this correct? Sloping a gutter downwards at the front reduces a gutter's capacity, thereby quite possibly/probably deeming the gutters to be no longer compliant with the NCC part 2 (BCA) regulations that apply to your gutter's required capacity for the roof areas that drain to each downpipe during a 1:20 year annual exceedance probability (AEP). I would be contacting the DFT for advice. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Yes, get a builder, make sure he is experienced and a registered building practitioner 5 9085 Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5973 |
