Browse Forums General Discussion 1 Nov 26, 2023 11:28 am Hi, I’m in the process of installing a new bath screen, It is 1500mm x 700mm x10mm, when I purchased it, it came with the glass and 2 wall mounting clips, I have installed the 2 mounting clips and am up to the stage of fitting the glass, My question is do I fit the glass directly on top of the bath or is the something that I am supposed to put under it? Cheers. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Frameless bath screen. 2Nov 26, 2023 12:24 pm Dcam Hi, I’m in the process of installing a new bath screen, It is 1500mm x 700mm x10mm, when I purchased it, it came with the glass and 2 wall mounting clips, I have installed the 2 mounting clips and am up to the stage of fitting the glass, My question is do I fit the glass directly on top of the bath or is the something that I am supposed to put under it? Cheers. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ You leave a gap under the screen that gets siliconed. That way the glass isn't touching the bath it's only the flexible silicone that joins the two. Glass installers have small clear Packers that they install under the glass to hold it up as they fix the glass in place. It gets cut and left in place under the silicone. If you haven't got the special packers you can just pack the very end and then silicone just up to it, then wait for the silicone to cure, remove the packers and compete the silicone. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Frameless bath screen. 3Nov 26, 2023 2:28 pm chippy Dcam Hi, I’m in the process of installing a new bath screen, It is 1500mm x 700mm x10mm, when I purchased it, it came with the glass and 2 wall mounting clips, I have installed the 2 mounting clips and am up to the stage of fitting the glass, My question is do I fit the glass directly on top of the bath or is the something that I am supposed to put under it? Cheers. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ You leave a gap under the screen that gets siliconed. That way the glass isn't touching the bath it's only the flexible silicone that joins the two. Glass installers have small clear Packers that they install under the glass to hold it up as they fix the glass in place. It gets cut and left in place under the silicone. If you haven't got the special packers you can just pack the very end and then silicone just up to it, then wait for the silicone to cure, remove the packers and compete the silicone. Thanks for the advise,much appreciated👍 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7276 Hello everyone Please advice me how can I install mesh security window or we cab say mesh flyscreen inside while the pvc plantation shutters are already installed? Is… 0 11875 Your shower screen has failed in the way it is designed to fail with tempered glass. You could replace it with laminated safety glass but make sure it has AS standards logo on it 1 11312 |
