Browse Forums General Discussion Re: Garage on boundary line. 2Oct 17, 2023 10:45 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Garage on boundary line. 4Oct 18, 2023 1:10 pm In WA zero lot is actually zero lot. We build 10mm in from the boundary. My house and my neighbours house have garages that sit only 20mm apart. They were both built at roughly the same time. When I had our roof done I had the roofers flash between the 2 garages so no moisture can get down the gap. The front gap is covered by a rendered trim so you can't see a gap there either. I don't understand why over east all the builds seem to sit 200mm from the boundary. It just introduces issues with drainage and cleaning not to mention it's a waste of 200mm of land. I guess that 200mm is to allow for space to put in drainage. I have to wonder how many people actually install the correct drainage before the brickwork starts because it will be impossible to get in there after the bricks go up if you have garages back to back as the OP has. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Garage on boundary line. 5May 16, 2024 11:12 am Hijacking this post as its relevant to my situation (VIC). My garage wall is on zero boundary and my neighbour's land (build hasnt started) has a little slope towards my side. Aside from the concreting around my house, my garage wall will have a Megaflo drain under the edge beam if I got the terms right. Builder said the Megaflo drain will only run within the garage wall so no issues on hitting during fencing. I think my garage wall will be my retaining wall since its on zero boundary. Anyone has used Megaflo and if you see any concerns on this set up that I should watch out for? Engineering Plans Retaining Wall with Megaflo DrainageLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16732 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17498 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 12244 |
