Browse Forums General Discussion Re: Pest Proofing Ventilation gaps in brick veneer home 2Oct 01, 2023 6:31 am lukeb0030 Hi all - i have some pests getting under my house. There are some larger points of entry which i will initally block off with Plywood, but i suspect some rodents could access the house via these ventilation gaps in my brick work (i assume they are for ventilation). Is there some product that i can use to pest proof these gaps with affecting the ventilation ? Any advice appreciated. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Brass fly wire, you will need to cut it, shape it and jam it into brick slots Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 5488 5 11125 DIY, Home Maintenance & Repair fair question about the slope. Re soil I mean that it doesn't look like reactive clay which swells and shrinks with wetness/dryness. If the floors in your house are… 3 20630 |
