Browse Forums General Discussion Re: Mains water to new house 4Sep 19, 2023 2:03 pm if it's the look that you're not happy with, the easiest option would probably be to spray paint it all into the same color as the walls so it blends in. there might not be a lot of work in moving it around the corner, not sure if it has any implications for approvals etc 6 5437 Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 5083 Thanks for clarifying. Sorry I misunderstood your point 7 7720 |
