Browse Forums General Discussion 1 Sep 17, 2023 11:42 am Hello! We have used Contempo Madrid Blanco (Midland Brick) in our gas fireplace and other areas in the house. Some of the bricks have a yellow discolouration which is very visible. Can these be cleaned? Or do we insist they be replaced? “Contempo Madrid is an imported product. Due to high density clay used, the moisture absorption rate is reduced when compared to locally manufactured clay brick products.” https://www.midlandbrick.com.au/Product ... rid-Blanco Thank you! Re: Feature brick discoloured 2Sep 18, 2023 9:42 am AsxTradingGirl Hello! We have used Contempo Madrid Blanco (Midland Brick) in our gas fireplace and other areas in the house. Some of the bricks have a yellow discolouration which is very visible. Can these be cleaned? Or do we insist they be replaced? “Contempo Madrid is an imported product. Due to high density clay used, the moisture absorption rate is reduced when compared to locally manufactured clay brick products.” https://www.midlandbrick.com.au/Product ... rid-Blanco Thank you! is it around the fireplace vent (as in is it heat that's caused the discoloration" or is it just random bricks here and there Re: Feature brick discoloured 3Sep 18, 2023 10:41 am ponzutwo AsxTradingGirl Hello! We have used Contempo Madrid Blanco (Midland Brick) in our gas fireplace and other areas in the house. Some of the bricks have a yellow discolouration which is very visible. Can these be cleaned? Or do we insist they be replaced? “Contempo Madrid is an imported product. Due to high density clay used, the moisture absorption rate is reduced when compared to locally manufactured clay brick products.” https://www.midlandbrick.com.au/Product ... rid-Blanco Thank you! is it around the fireplace vent (as in is it heat that's caused the discoloration" or is it just random bricks here and there Just random bricks - house is still under construction. Re: Feature brick discoloured 4Sep 18, 2023 2:47 pm AsxTradingGirl ponzutwo AsxTradingGirl Hello! We have used Contempo Madrid Blanco (Midland Brick) in our gas fireplace and other areas in the house. Some of the bricks have a yellow discolouration which is very visible. Can these be cleaned? Or do we insist they be replaced? “Contempo Madrid is an imported product. Due to high density clay used, the moisture absorption rate is reduced when compared to locally manufactured clay brick products.” https://www.midlandbrick.com.au/Product ... rid-Blanco Thank you! is it around the fireplace vent (as in is it heat that's caused the discoloration" or is it just random bricks here and there Just random bricks - house is still under construction. hmmm id assume youll get hit with the "natural product therefore variation in colour etc" excuse. How bad are we talking? One could argue that if none of the displays or other installs of the brick show such discolouration or variations, then the ones you have are faulty/defective Good day everyone, I have two queries regarding stacked stone style facade feature tile installation. 1. I am looking for an installation price guide to install stacked… 0 1796 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 21348 If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8880 |
