Browse Forums General Discussion Re: New house land/slab drainage? 5Sep 10, 2023 8:10 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: New house land/slab drainage? 7Sep 11, 2023 11:54 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: New house land/slab drainage? 11Sep 11, 2023 2:42 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: New house land/slab drainage? 14Sep 14, 2023 1:16 pm groundzero Froth alexp79 They usually never put it on the plans per se, however, in the notes the plans usually say that builder has to provide drainage to the site if necessary. What type of soil you are on? Thanks for the reply. The soil is sandy, located in cranbourne, vic. I think it mentions grading of soil around the house , the builders only partially did that. The back corner has pooling water. My main concern is slab heave. The geofabric under the rock garden should be okay with drainage hopefully. Cranbourne has highly reactive soils as well and a history of cracked houses so I would be careful depending where you are in Cranbourne. Thanks for the heads up mate, greatly appreciated 👍 Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12493 2 6002 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3200 |
