Browse Forums General Discussion 1 Sep 06, 2023 5:04 pm I have a new house that we occupied 8 months ago. It had a slow leak detected by plumber between the wall between 2 bathrooms. Apparently the leak has been fixed. I am still smelling a strong mouldy smell. The builder & plumber said it will take some time to dry out as it has been leaking for a while. Should I accept this, or should they be pulling bathroom cabinet out to dry it out, & remove mould? I am only just now seeing some slight warping on the inside of shaving cabinet. Will the smell go when it drys out? Re: Leak in wall new house 2Sep 06, 2023 8:31 pm Mould is a health hazard and a strong mouldy smell is concerning. I recommend independent inspection and second opinion. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5163 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17567 Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 11537 |
