Browse Forums General Discussion 1 Aug 26, 2023 3:35 pm Hello all, We're at the design stage. Its a knockdown rebuild on highly reactive clay soil. We have an engineered raft slab design, with beam footings spec'ed at 700mm minimum from top of floor to bottom of footing or at least 100mm into solid ground One design option will require a sewer pipe running under the slab across the house for about 13 metres basically from one side of the house across to the other. I'm worried about soil movement that might later damage this pipe. Anyone have any experience or opinion if this a valid concern or am I overthinking it? Re: Sewer pipes under slab 2Aug 27, 2023 10:24 am stefcep Hello all, We're at the design stage. Its a knockdown rebuild on highly reactive clay soil. We have an engineered raft slab design, with beam footings spec'ed at 700mm minimum from top of floor to bottom of footing or at least 100mm into solid ground One design option will require a sewer pipe running under the slab across the house for about 13 metres basically from one side of the house across to the other. I'm worried about soil movement that might later damage this pipe. Anyone have any experience or opinion if this a valid concern or am I overthinking it? Re: Sewer pipes under slab 3Aug 27, 2023 11:48 am That is a question your engineer needs to answer in the design detail. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Sewer pipes under slab 4Aug 27, 2023 12:02 pm Below is a link to a post by a leading slab heave expert. viewtopic.php?p=1206402#p1206402 Also, if AS 2870 is referenced in the contract, make sure it is not only referenced to the slab which is construction. It must also be referenced as plumbing if you want to include flexible joints etc. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Sewer pipes under slab 5Aug 27, 2023 1:14 pm SaveH2O Below is a link to a post by a leading slab heave expert. viewtopic.php?p=1206402#p1206402 Also, if AS 2870 is referenced in the contract, make sure it is not only referenced to the slab which is construction. It must also be referenced as plumbing if you want to include flexible joints etc. Thanks that link in particular is really useful. To me, that's what it looks like: poor backfilling and/or compaction. The width is about 1000mm maybe. That conduit in the photo is for the NBN. The water is about… 4 8514 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 20810 Just removed 40 liters of water in the span of 2 hours. Water fills up the hole just above the seepage point and doesn't overflow. 1 1446 |
