Browse Forums General Discussion 1 Aug 18, 2023 12:56 pm Hi Just wondering if anyone has had plastering like this done around door frames? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Some of them have only been done on one side. How would it get painted? The frames should be semi-gloss white, and the walls are Lexicon quarter. this would mean 2 different depths of wall colour..?? I don't know if my symmetrical particularness can survive this... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Solid plastering around door frames - help... so confuse 2Aug 18, 2023 1:35 pm Hi Cat. By the look of that I assume you are in WA. Unfortunately that is fairly common particularly in toilets where there is a small gap next to the frame. I agree it looks horrible and really it's the plasterer being lazy. It's very hard to get into the little gap and trowel and finish the float and set, so they build it out to the frame. A good plasterer will take the time and have tools that let them get in there but the majority of project homes will get finished like that. And yes, it will be up to the painter to try and make it look somewhat decent. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Solid plastering around door frames - help... so confuse 3Aug 18, 2023 3:12 pm chippy Hi Cat. By the look of that I assume you are in WA. Unfortunately that is fairly common particularly in toilets where there is a small gap next to the frame. I agree it looks horrible and really it's the plasterer being lazy. It's very hard to get into the little gap and trowel and finish the float and set, so they build it out to the frame. A good plasterer will take the time and have tools that let them get in there but the majority of project homes will get finished like that. And yes, it will be up to the painter to try and make it look somewhat decent. Hi, thanks for your reply. Do you think that given it's a custom build of around $650k, I should pursue a more quality finish? Re: Solid plastering around door frames - help... so confuse 4Aug 18, 2023 3:14 pm chippy Hi Cat. By the look of that I assume you are in WA. Unfortunately that is fairly common particularly in toilets where there is a small gap next to the frame. I agree it looks horrible and really it's the plasterer being lazy. It's very hard to get into the little gap and trowel and finish the float and set, so they build it out to the frame. A good plasterer will take the time and have tools that let them get in there but the majority of project homes will get finished like that. And yes, it will be up to the painter to try and make it look somewhat decent. Also, directly behind one door, with the same gap of 45mm, it is finished perfectly - so we know he's capable Re: Solid plastering around door frames - help... so confuse 5Aug 18, 2023 3:29 pm chippy Hi Cat. By the look of that I assume you are in WA. Unfortunately that is fairly common particularly in toilets where there is a small gap next to the frame. I agree it looks horrible and really it's the plasterer being lazy. It's very hard to get into the little gap and trowel and finish the float and set, so they build it out to the frame. A good plasterer will take the time and have tools that let them get in there but the majority of project homes will get finished like that. And yes, it will be up to the painter to try and make it look somewhat decent. Holy crap that looks terrible! Thanks for the explanation chippy. But why don't they put the architraves on after setting and sanding? just flip the order Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Solid plastering around door frames - help... so confuse 6Aug 18, 2023 3:44 pm Ashington Homes chippy Hi Cat. By the look of that I assume you are in WA. Unfortunately that is fairly common particularly in toilets where there is a small gap next to the frame. I agree it looks horrible and really it's the plasterer being lazy. It's very hard to get into the little gap and trowel and finish the float and set, so they build it out to the frame. A good plasterer will take the time and have tools that let them get in there but the majority of project homes will get finished like that. And yes, it will be up to the painter to try and make it look somewhat decent. Holy crap that looks terrible! Thanks for the explanation chippy. But why don't they put the architraves on after setting and sanding? just flip the order Not just me then? The site manager blew it off... like too bad, that's how it's done. The metal door frames are bricked in by the brickies, but on the plans there is no gap - as in the door frame is built to the edge. But it's also completely random where it's been done AND we paid $1200 extra for those modular frames! If they absolutely had to, I would have considered flushing in the frames, but only if the entire wall got done to maintain a level finish. Sadly, we were never consulted - as usual. Re: Solid plastering around door frames - help... so confuse 7Aug 18, 2023 3:47 pm catb9 Ashington Homes chippy Hi Cat. By the look of that I assume you are in WA. Unfortunately that is fairly common particularly in toilets where there is a small gap next to the frame. I agree it looks horrible and really it's the plasterer being lazy. It's very hard to get into the little gap and trowel and finish the float and set, so they build it out to the frame. A good plasterer will take the time and have tools that let them get in there but the majority of project homes will get finished like that. And yes, it will be up to the painter to try and make it look somewhat decent. Holy crap that looks terrible! Thanks for the explanation chippy. But why don't they put the architraves on after setting and sanding? just flip the order Not just me then? The site manager blew it off... like too bad, that's how it's done. The metal door frames are bricked in by the brickies, but on the plans there is no gap - as in the door frame is built to the edge. But it's also completely random where it's been done AND we paid $1200 extra for those modular frames! If they absolutely had to, I would have considered flushing in the frames, but only if the entire wall got done to maintain a level finish. Sadly, we were never consulted - as usual. i just sent that photo to my business partner, and we nearly wet ourselves with laughter at how bad some builders are and what they try and get away with. Have some pride in your work for gods sake! Not sure what else to say other than I would be getting it ripped off and reset. Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Solid plastering around door frames - help... so confuse 9Aug 19, 2023 12:19 pm I'm not sure what to say about that! You must have other issues there as well Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Solid plastering around door frames - help... so confuse 10Aug 19, 2023 2:15 pm If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify wider architraves. I many case where a gap does happen but is less than 18mm the usual remedy is a timber fillet which will look acceptable. I think the builder parked his brain in neutral when setting out the door frames. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 10213 Screed is installed before or after, what was not up to code? You have 4x images, door frame, The work is poorly applied rough, with no care for how it should be done, if… 5 3118 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16269 |
