Browse Forums General Discussion 1 Aug 12, 2023 11:06 pm We recently purchased a house that we love. At the time we accepted that there is an easement for water drainage and a sweage man hole on the property but since it is right in the middle of it, I wanted to get an opinion on the situation. There is no easement mentioned in the contract for the manholes or the sewage line. Did we make a huge mistake and will this impact on the resale value of the home? Thanks in advance. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Is this a bad situation - easement and manhole on proper 2Aug 15, 2023 8:42 am You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not this is possible as you wont be able to build over a manhole. Generally you can build over a sewer if you encase it, but this needs approval and a design. Not sure what the situation is in other states though. But you still have the issue of the 1.83m wide drainage easement which is a pain. I have built on industrial sites where we have had large drainage easements through the property which had 1000mm diameter concrete pipes and we applied to relocate these and modify the easement. But you need permission from the person who has the benefit of the easement. It will be an expensive process unfortunately and yes it does devalue your property, but conversely if you can move those easements you will add value. I hope this helps a little Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Hey guys, need your help and experience in relocating a sewer manhole in our land. I am looking to building a duplex in this land. But there is a sewer manhole located… 0 136 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17455 |
