Browse Forums General Discussion Re: Foil wrap not done before brickwork 7Jul 31, 2023 3:12 pm Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Foil wrap not done before brickwork 8Jul 31, 2023 3:30 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Foil wrap not done before brickwork 9Dec 25, 2023 9:57 am Ashington Homes aliminter Hi, we are having a duplex built in Sydney. The contract says the Sisal Foil wrap will be applied to all external walls. Is this meant to be applied to the framing before the brickwork is done? We have just noticed that there is none and the brick veneer has been finished. Could they still apply it now? You can definitely do it on the inside before gyprock, so all is not lost. You can even pick a good quality class 4 vapour barrier and you should get a good result. The key though is getting them to tape all the joins and penetrations. If you have time I would be happy to show you a build we are doing where we have done this, but you need to get your builder to agree to it. cheers Simeon I am in the same situation, would you be able to give some insights in to this? I am in SA I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 15696 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 4634 |
