Browse Forums General Discussion 1 Jul 16, 2023 5:55 pm Hi, I bought this saw over 10 years ago, used it once, and packed it away. Now want to use it again, and all the blades in Bunnings have large bore sizes. I need a 125mm blade with a bore (arbor) size of 14mm (measured with calipers) but all the bushes that come with the blades seem to only go down to 16mm. Am I being too precise, and the 16mm would be OK, as long as tightened properly? Or have I managed to lose a bush that would have come with the saw? Any advice much appreciated. UPDATE I have a spare blade with a bush, but the bush is too big, so won't fit on the arbor. It appears to be two rings, but they're siezed together and I need the outside one. I can't separate them, so will go looking for a bush set at Bunnings, ir buy another blade and try the bushes that come with it. Fine with me... just let 'em step in with some affordable (but good) gear... 12 5645 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3683 Dear all, Requesting your help in relation to a CDC code. We are building a new home in NSW on a corner lot (500m2, 15m wide) following Greenfield CDC code. Our design… 0 6318 |
