Browse Forums General Discussion 1 Jun 28, 2023 1:55 pm There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water in. Do I need to close off that small gap between the drip edge and the corrugated iron sheet, if so, what products would one typically use? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thank you @ashington Homes for your reply! They just got back to me and offered credit for me to just take it as is. It was a less than quotes I got from ceiling… 6 1907 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6250 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17378 |
