Browse Forums General Discussion 1 Jun 18, 2023 12:39 pm We've got a glass brick wall in our bathroom...the other side of the wall is external. Was installed about 15 years ago...8 blocks across and 9 high. A decent number of them have cracked - probably quarter of them. I have toyed with the possibility of just replacing the broken ones...but now I think I'll get the whole thing replaced. Couple of questions. Is this an OK DIY job? I'm pretty handy...have built a few brick walls before...so it doesn't really faze me. But wondering if there's anything here that is too complex for a DIYer? Secondly...the current wall has a metal frame around the blocks that I've always found pretty ugly (see below). I'd much rather the blocks just butt up against the walls on either side - which are brick. So rather than the metal frame, perhaps some grout or mortar instead. Or do these things definitely need this metal frame? I'm off to the glass brick shop in a couple of weeks...but just thought I'd ask here first. Cheers Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Assuming the structure of your cabinetry is good then I would DIY everything as follows: - replace your counter tops entirely, - replace all drawer runners with soft close… 1 4989 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5943 a building inspector should be able to tell you about any major problems but we need a floor plan with dimensions to clarify options for extra bedrooms ... sometime an… 1 9017 |
