Browse Forums General Discussion 1 Jun 12, 2023 10:17 pm Hello, I’m sure this is a popular question and I’ve found it on many other forums but have struggled to find an answer so I’m asking it here. My house is higher up then my neighbours and a retaining wall between my concrete path and there garage wall (my boundary wall) because of this I have a 300mm gap between neighbours house and my concrete path. Water pools up in that gap and because they are lower down water can get into neighbours weep holes. I want to fill it with crush rock and raise weep holes higher. Is this possible? My only other option is dig down further and out a drain the length on neighbours garage. But then I’ll have this ugly trench between my neighbours wall and my concrete path. What’s the best way to go about this that won’t compromise the structural integrity of my neighbours wall and that does comply with the standards? (Victoria, Australia) Thank you Re: Weep holes neighbours 2Jun 13, 2023 6:08 pm it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you can’t fill against their wall, you need to retain and leave a gap I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5634 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11491 Building Standards; Getting It Right! Hi, sorry if this is the wrong place - I’m new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 19459 |
