Browse Forums General Discussion 1 May 18, 2023 9:00 pm Hi all, I am currently building a verandah. I have dug the footings for the stirrups/posts. The footing holes are 300 x 300 x 1000, which need to be filled with concrete. One of the holes has a PVC pipe (storm water I think) running through the centre, directly under the stirrup. The stirrup sits about 80mm above the pipe. Should I move the pipe, protect it somehow or just concrete around it? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any advice is appreciated. TIA Re: PVC pipe through footing 2May 19, 2023 10:08 am bridge the pipe with a bigger footing, dig down to undisturbed soil either side, wrap the pipe in 2 layers of 10mm adhesive backed foam abelflex expansion “sticky back”, then get some 12mm deformed rod to span over it, or move the pipe. don’t concrete it in or bear on it. If best on backfill it will settle and the concrete will crack your pipe. Re: PVC pipe through footing 3May 19, 2023 4:24 pm Pulse bridge the pipe with a bigger footing, dig down to undisturbed soil either side, wrap the pipe in 2 layers of 10mm adhesive backed foam abelflex expansion “sticky back”, then get some 12mm deformed rod to span over it, or move the pipe. don’t concrete it in or bear on it. If best on backfill it will settle and the concrete will crack your pipe. Thanks Pulse for the reply. Just to clarify, the hole extends another 400mm below the pipe, it is it just full of water due to the rain we had. I think I will wrap it as you mentioned and span over it with deformed rod to shift as much weight off the pipe as possible. Hi all, I'm excavating a footing to build a front wall next to the footpath. I've excavated the footing (8 m long, 600 wide, 600 mm deep) and there is an old sleeved gas… 0 684 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 5101 DIY, Home Maintenance & Repair You might want to consider trenchless pipe replacement to solve the issue of roots blocking your pipes. By connecting the three upstairs bathroom… 3 1436 |
