Browse Forums General Discussion 1 Oct 01, 2020 8:17 am Hi All, I am new to this forum. I have a 3 yr old house and have recently started hearing cracking and popping noises from roof and wall of my house. There are no cracks internally or externally in the house. Should I be worried about this? Re: Cracking and popping noises in roof and walls 2Oct 01, 2020 10:38 am Easy007 I have a 3 yr old house and have recently started hearing cracking and popping noises from roof and wall of my house. There are no cracks internally or externally in the house. Should I be worried about this? I presume you have a Colorbond roof. The roofing material expands and contracts with temperature, and that's likely what is causing the popping and cracking sounds. Ours does it all the time. There is plenty of flexibility up there and I don’t think you have anything to worry about. Re: Cracking and popping noises in roof and walls 3Oct 01, 2020 10:40 am arcadelt Easy007 I have a 3 yr old house and have recently started hearing cracking and popping noises from roof and wall of my house. There are no cracks internally or externally in the house. Should I be worried about this? I presume you have a Colorbond roof. The roofing material expands and contracts with temperature, and that's likely what is causing the popping and cracking sounds. Ours does it all the time. There is plenty of flexibility up there and I don’t think you have anything to worry about. Thanks for you response. Sorry I should’ve mentioned it but mine is a cement tiles roof. Cracking and popping noises in roof and walls 4Oct 01, 2020 1:14 pm Easy007 Sorry I should’ve mentioned it but mine is a cement tiles roof. I've never owned a new house with a tile roof so can’t say for sure, but it is possible it’s the same thing. Even more flexibility with tile roofs as the tiles generally aren’t tightly fixed to each other. Perhaps someone with a new tile roof can comment more definitively than me. Perhaps try and note if the sounds get worse as the sun shines directly on the roof. I notice it most on partly cloudy days, as the sun comes in an out of the shade of the clouds. Re: Cracking and popping noises in roof and walls 5Oct 01, 2020 1:25 pm arcadelt Easy007 Sorry I should’ve mentioned it but mine is a cement tiles roof. I've never owned a new house with a tile roof so can’t say for sure, but it is possible it’s the same thing. Even more flexibility with tile roofs as the tiles generally aren’t tightly fixed to each other. Perhaps someone with a new tile roof can comment more definitively than me. Perhaps try and note if the sounds get worse as the sun shines directly on the roof. I notice it most on partly cloudy days, as the sun comes in an out of the shade of the clouds. Re: Cracking and popping noises in roof and walls 6Oct 01, 2020 1:25 pm structuralBIMGuy do you have any advice on this? Re: Cracking and popping noises in roof and walls 8Oct 02, 2020 6:49 am Generally a home well built should not have cracking and popping noises. It could be thermal expansion but more likely foundation movement . What is your site soil classification? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Cracking and popping noises in roof and walls 9Oct 02, 2020 11:19 am StructuralBIMGuy Hey Easy007 More info required, Type- Truss or stick, Material- Timber or Steel? Photos within the roof also help Cheers Chris Hi structuralBIMGuy, It is a timber truss. Please see attached pics. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Cracking and popping noises in roof and walls 10Oct 02, 2020 11:30 am building-expert Generally a home well built should not have cracking and popping noises. It could be thermal expansion but more likely foundation movement . What is your site soil classification? I am not sure about the soil classification. How do I get it? I also noticed today the noise are coming both from roof and aluminium windows and more prominent during mornings and evenings. Does it fit more into the criteria of thermal expansion? Re: Cracking and popping noises in roof and walls 11Oct 05, 2020 9:31 am Building permit documentation should have soil classification noted on engineering drawings or there is geo technical report Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Cracking and popping noises in roof and walls 12Apr 06, 2021 8:12 am sometimes l get a loud pop or crack noise coming from the roof , ususally the same area, it happens during the day, l have a colorbond roof, is it most likely caused by the heat of the day on the roof and timber beams. l hope its not foundation movements, l dont have any cracks in the walls Re: Cracking and popping noises in roof and walls 13May 22, 2023 10:33 pm Easy007 Hi All, I am new to this forum. I have a 3 yr old house and have recently started hearing cracking and popping noises from roof and wall of my house. There are no cracks internally or externally in the house. Should I be worried about this? hey, did you manage to find those strange popping nd craking sounds from roof? getting similar sounds from my tiles roof of recently purchased property. Structural inspector said no fault at all in structure of this 10yr old house. Re: Cracking and popping noises in roof and walls 14May 23, 2023 7:37 am I thought it was common for new and old houses to make expanding and contracting noises. Especially those with timber trusses... It takes half your life before you discover life is a do-it-yourself project. - Napoleon Hill Re: Cracking and popping noises in roof and walls 15May 23, 2023 8:56 am DIY_Debbie I thought it was common for new and old houses to make expanding and contracting noises. Especially those with timber trusses... it is to a degree, but these sounds tend to be fairly obvious so when you hear something out of the ordinary it can be concerning. Re: Cracking and popping noises in roof and walls 16May 23, 2023 9:15 am ponzutwo DIY_Debbie I thought it was common for new and old houses to make expanding and contracting noises. Especially those with timber trusses... it is to a degree, but these sounds tend to be fairly obvious so when you hear something out of the ordinary it can be concerning. Agree, and the frequency is high too. I put lots of efforts to identify the trusses, loose water pipes etc which could be the main culprits, even put cctv cameras around the ceiling but no success. Ain't that the truth! We used to have a tile roof and had it replaced with colorbond and suddenly everything throughout the entire house sounds louder! 4 7844 0 2227 Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 13949 |
