Browse Forums General Discussion 1 Mar 30, 2023 8:44 pm Evening, Had my 3 month maintance done on my new place. Most things are fixed to ok standards, but im not sure about the visible joins in my plaster wall. There was 2 vertical plaster joints showing, only when standing directly in front of them. Builder has feathered/skimed them out, let dry for a day then sanded and applied 2 coats of paint to whole 11m lenght of wall. The joins are looking worse than before now from far away, up close they disappear. I've put a leverer against the wall and wall is completely flat, no bumps. I've read about glansing light, which I have, only having 1 large triple door at end of the room. Is there any way of fixing this? Before i go buy a large painting to try hide it. It grabs my attention as soon I enter the room now. Wish they left the wall as it was now. Thanks for the advice. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 10989 Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4603 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 2657 |
