Browse Forums General Discussion 1 Mar 30, 2023 6:47 am HI guys I have just hired someone did a concrete driveway for me and 14 days later the very end conor cracked.and its not hairline crack..He came back put some poly gap filler thats all. I wonder if thats legit??? pls see videos and pics for previous gap and afterwards/// and basically when he back to work he has been quite rude said i did dodg things to concrete etc. should i sue him ? ? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: new concrete driveway crack 2Mar 30, 2023 12:31 pm i havent watched the videos as im at work, but if the crack is the one in the picture, you have got to be kidding me about the fuss youve made lol. Concrete cracks. The control joins are there to try and force the crack to occur along them (sometimes it does, other times it doesn't). Re: new concrete driveway crack 3Mar 30, 2023 1:12 pm ponzutwo i havent watched the videos as im at work, but if the crack is the one in the picture, you have got to be kidding me about the fuss youve made lol. Concrete cracks. The control joins are there to try and force the crack to occur along them (sometimes it does, other times it doesn't). When you get a chance watch the last couple of videos. The cracks are pretty bad, it's almost as though he hasn't put any reo in that corner and hasn't compacted/levelled that corner resulting it it snapping off. The fix is easy though. That corner can be cut off, insert some dowels and re-laid. Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Most likely poor foam installation and render installation, Joint covered with render, foam could be sitting on flashing. Do you have any render at house 4 9572 Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 11039 you need to make an application to your local council for this as they are the approval authority for driveways cheers Simeon 1 7101 |
