Browse Forums General Discussion 1 Feb 24, 2022 9:55 pm Need some advice my storm water, the street fills up so much in my section my storm water can’t get out. Just bought the property and contacted council and engineer came out and said there is no problem, how do I get my storm water out. This was after a small down pour. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Storm water exit point 2Feb 25, 2022 11:54 am The last photo shows the full pipe at the discharge which means that you are losing about 100 mm head. All you can do is increase the head. Does the pipe connect to a silt pit or does it only service downpipes, i.e. you have no surface or ag drainage? Are the downpipes metal or pvc? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Storm water exit point 3Feb 25, 2022 3:26 pm SaveH2O The last photo shows the full pipe at the discharge which means that you are losing about 100 mm head. All you can do is increase the head. Does the pipe connect to a silt pit or does it only service downpipes, i.e. you have no surface or ag drainage? Are the downpipes metal or pvc? No silt pit and only for down pipes, they are pvc. sorry can you explain in a bit more detail as I don’t understand what you mean I’m loosing 100mm of head Re: Storm water exit point 4Feb 25, 2022 5:57 pm It looks like a 90mm pvc pipe. If the pipe is full, you will lose hydraulic head to that point but there will still be positive head above that point. Looking at the photos, I would be surprised if you didn't still have an adequate hydraulic head. Apart from visuals, is there another reason for concern? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Storm water exit point 5Feb 26, 2022 6:36 pm SaveH2O It looks like a 90mm pvc pipe. If the pipe is full, you will lose hydraulic head to that point but there will still be positive head above that point. Looking at the photos, I would be surprised if you didn't still have an adequate hydraulic head. Apart from visuals, is there another reason for concern? My water isn’t getting onto street with the water covering the outlet Re: Storm water exit point 6Feb 26, 2022 8:35 pm Then where is it going? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Storm water exit point 8Mar 04, 2022 5:29 pm kat4 SaveH2O It looks like a 90mm pvc pipe. If the pipe is full, you will lose hydraulic head to that point but there will still be positive head above that point. Looking at the photos, I would be surprised if you didn't still have an adequate hydraulic head. Apart from visuals, is there another reason for concern? My water isn’t getting onto street with the water covering the outlet Completly lost!! Where is your water going? If not coming out there it would back up your downpipes , no? Causing another problem Re: Storm water exit point 10Mar 07, 2022 5:34 pm You need to have a CCTV inspection as there should be noticable flow at the kerb if the downpipes are full. That is a hell of a lot of hydraulic head, you clearly have an obstruction in the pipe.The water level at the kerb is a red herring. How long have you lived in the house and is this a relatively recent problem? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 8007 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6978 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10740 |
