Browse Forums General Discussion 1 Feb 06, 2022 4:40 pm Hi, We bought a 3.75m x 1.25m garden shed, the plan is to put it on a car space/concrete slab that is at the side of the house. Problem is it's not particularly level, puddles when it rains etc. The only thought I've had is to raise a section with self levelling concrete but I've never used it before. If this is OK, how thick would it need to be so it doesn't crack? Any simpler ideas also appreciated 👍 Re: Uneven concrete slab! 2Feb 09, 2022 9:30 am Instead of going down the self leveling road you could build a platform for it out of timber and decking boards and level the platform. That's what I did. It gets the shed floor off the ground as well so any water down the driveway won't be an issue either. I hope this help you newhome_24, AS3958.1 is the Ceramic Tile Installation Standard. It specifies the tolerances for the installation of tiles. The tile supplier is… 1 7735 I don't think you're getting a response because you are not quite clear on what the issue is. yep, the site is not level, no site is! but are you just building a garage?… 1 2887 The concreter will take and reuse. In my case I bought structural LVLs and scraped them back and used them as joists. 1 5439 |
