Browse Forums General Discussion 1 Apr 30, 2021 8:37 pm Hi, I have a smell trouble now after we did pressure water cleaning outside of our house. Please help me. Only one room smells bad, I smell like an old dirty wet cloth smell in the room. Maybe bacteria but smells like wet yukky towel smell. I feel like the smell is coming from wall or ground? When I go outside near the room, I don't smell it. My house is over 30 years old. Do you know how to fix this smell problem? The smell started one day after pressure cleaning so I am sure it's from cleaning. Thank you so much. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ (This photo is before the cleaning.) Re: Smelly room after outside pressure cleaning 2May 12, 2021 12:05 pm The stucco might be penetrated with water from the pressure washer and accumulated between blocks causing the musty smell. Try everything to completely dry the room. Open all the windows and doors. Otherwise, you might need to tear out a part of your drywall and run an air mover. Re: Smelly room after outside pressure cleaning 3Feb 13, 2024 1:58 am NO1 Carpet Cleaning Melbourne The stucco might be penetrated with water from the pressure washer and accumulated between blocks causing the musty smell. Try everything to completely dry the room. Open all the windows and doors. Otherwise, you might need to tear out a part of your drywall and run an air mover. Sorry for my late reply! I just saw your comment now. After a few months, the smell disappeared. It took a while. I need to be careful if I clean the house. First time building 2 storey home, is under construction (in Framing stage) in NSW. I have 3 toilets and need bidet spray in… 0 17413 Hi all, My concrete tile roof (pictured here: https://imgur.com/a/d2GiHJH) over the last 5 years has gotten to the point it needs a clean. Unsure why previous owner… 0 1235 |
