Any movement will not be absorbed by your articulation joints and will be reflected in your brickwork.
Hi so you are saying its the joint issue not ground slab issue?
Browse Forums General Discussion Re: Hebel wall hairline cracks on new house built 2020..why? 21Mar 30, 2023 5:50 am groundzero Your articulation joints have been rendered over so they will not work. Any movement will not be absorbed by your articulation joints and will be reflected in your brickwork. Hi so you are saying its the joint issue not ground slab issue? Re: Hebel wall hairline cracks on new house built 2020..why? 22Mar 30, 2023 5:59 am Thank you guys. I had the builder here last week and he had a look said its not slab issue. only the hebel issue and my cctv cam has recorded what he said...so if later bad happens I have evidence??? Re: Hebel wall hairline cracks on new house built 2020..why? 23Mar 30, 2023 6:49 am Ethan in Adelaide Thank you guys. I had the builder here last week and he had a look said its not slab issue. only the hebel issue and my cctv cam has recorded what he said...so if later bad happens I have evidence??? You asked the fishmonger if his fish was fresh.....you never ask the fishmonger if their fish is fresh. Re: Hebel wall hairline cracks on new house built 2020..why? 24Mar 30, 2023 6:59 am Ethan in Adelaide groundzero Your articulation joints have been rendered over so they will not work. Any movement will not be absorbed by your articulation joints and will be reflected in your brickwork. Hi so you are saying its the joint issue not ground slab issue? Have you had floor levels done ? that would be a good starting point Re: Hebel wall hairline cracks on new house built 2020..why? 25Mar 31, 2023 10:45 am Buy yourself a laser level and start logging the slab movements your egineer should be able to match the calcs/simulations with movements and cracks Checking room Dimensions (XYZ Co ordinates with Bosch lasers Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Hebel wall hairline cracks on new house built 2020..why? 26Mar 31, 2023 7:05 pm I'm sure this hairline crack along the joints will still be there in 20 years time whatever u do and also in 20 years time your house will be be standing. It's cosmetic really. Your house is supported by the frame not the Hebel. It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17872 Do I need to concern about this pattern of crack? Is this crack showing some signs of bigger problems? Thanks for any suggestions! 1 2164 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6799 |
