Browse Forums General Discussion 1 Aug 09, 2005 3:25 pm Hello everyone, I have a question regarding roof restoration. We have a two story concrete tile roof and have had a couple of qoutes to restore the roof. Now my problem is the qoutes range from $3050 upto $6740. Do you really think there would by much difference between companies to warrant such differences in qoutes. Is there anything I should be wary of?Also do I have to have Safety rail put up around the roof while they are carrying out the work?
Any help would be much appreciated. Thanks. Roof restoration 2Aug 11, 2005 8:35 am A safety rail will need to be installed & this should form part of the quote.
If the firms are quoting on exactly the same work (& allowing for the same items such as site clean up etc then the prices should be similar) when you receive a quote it ashould be detailed and not just "replacement of roof tiles" or the like. Larger firms may have bigger overheads ( & better buying power) but their prices should be competitive across the board. With such variations in price I would be looking at obtaining further quotes before making a decision. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Hi I bought an old cupboard that is in desperate need of some TLC. I was seeking some advice as to the best product to use to give it an oil but also bring it to life a… 0 3623 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 12034 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5870 |
