Browse Forums General Discussion 1 Feb 10, 2024 3:09 pm I have some render that needs repair. I can see it's been repaired in other places though they've had a hard time replicating the scratch style pattern (they look to have run a nail through it randomly and it doesn't look the same as the rest).
Does anyone know what this pattern is called and how to do it? Looks like this, maybe that's what they used: https://ultratexvic.com.au/ultratex-tex ... h-texture/ Re: Replicate render scratch pattern 3Feb 11, 2024 11:41 am Generally, the texture that you listed will have a 2mm size stone chip in it which is dragged with float to give the lines Any patch work needs to be 2mm less than face of wall then the scratch texture applied I am looking for someone who might have tackled a similar issue as me. I have a few rendered interior walls, the surface condition is hardly flat. I can see all the bumps… 0 8319 Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,… 5 7296 |
