Browse Forums General Discussion Re: How to remove or repair Klip-Lok roof sheets? 2Feb 24, 2023 12:26 pm Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: How to remove or repair Klip-Lok roof sheets? 4Feb 25, 2023 5:01 am gommeqld Thanks Simeon, I'll PM you my email address although to benefit others on the forum can you post the video or a link to it on here? I have tried emailing them, hope the links work. I am so technologically deficient I am not not sure how to post them here, so if you are able to I would be happy for you to share publicly. FYI, the reason why we had to remove a sheet of klip lok was that one of our overly enthusiastic gyprockers shot 6 or 7 screws through from underneath an alfresco ceiling. From memory as this was 2019, there were only one or two sheets damaged. The roofers didn't think they would be able to get the sheets off, actually they were pretty confident it was near impossible, but they agreed to try. The gyprocker offered to pay for a whole new roof if they couldnt get the the 2 sheets off. Anyhow, the boys managed to successfully pry the sheets off without any damage. if you look closely you can see the screwsLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. As above, you will need to trim your sheet to land on the joist, also make sure you are running your length at right angles to the joists 2 1799 8 5630 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6555 |
