Browse Forums General Discussion 1 Jan 13, 2021 3:00 pm Just a question on the rainwater tank plumbing... I've noticed some plumbing were fitted above my rainwater tank. I am just not 100% sure how it works. I've checked and confirmed the inlet on the right is only going to the toilets in my house (by turning off the knob and no water is filling the toilet canister). If I turned on the yellow tab water will leak out from the terminal fitting below the tab. So if I say the plumber is just install the basic plumbing for using water from Mains to flush toilet, but left a connection to the rainwater tank right? Is that a specialised T-piece that can switch Rainwater / Mains? or I will need to buy a specialised T-piece to switch Rainwater / Mains? Any recommendations that is affordable? Thanks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ if it's the look that you're not happy with, the easiest option would probably be to spray paint it all into the same color as the walls so it blends in. there might not… 3 4328 Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31467 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17848 |
