Hi Guys and Gals,
Can anyone give me a indication of the cost per square metre for the SLAB and the Drivway in sydney.
Cheers.
Browse Forums General Discussion Re: Cost of Slab and DRIVEWAY 2Sep 11, 2006 10:59 am Hanibal,
Not all slabs are created equal! It will depend on how thick the slab is, type of reinforcement used, depth/width of footings, use of cantilevered footings, piering, etc, etc. Short answer, cannot be priced without seeing engineer's drawings. Re: driveway, again depends on lots of things - gradient of drive, thickness, reinforcement, edge thickening, loadings, drainage, etc. Roughly though, you are looking at about $75/m2 inc. GST for a 150mm thick road with SL72 mesh. Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 8365 custom probably not. Volume, most defiantly, but spec would vary. If youre doing a knock down, there additional costs associated with that that will eat into your budget… 1 10599 Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 8538 |
